WTF is this ?
WTF is this ?
i took of the oil pan today to tap another hole for the second turbo drain because i am switching from a single to twin
and after i took the oil pan off i decided to look at the cylinder bores, and found this
how did this happen ? this motor only has around 6000miles on it
your rings most likely had a burr on them when it was installed it is a common thing to see in a fresh when the rings are not correctly deburred. If it not too deep let it ride.
