Are Relocation Brackets Necessary?
After I installed my relocation brackets w/ LCA's and PHB all my my wheel hop disappeared even before I was able to install am aftermarket torque arm. You will notice a difference with traction for sure with just relocation brackers on a DD. Recommended.
LS1Tech Administrator
Received 1,483 Likes
People talk about the 10-bolt like it's made of paper. It's not THAT bad, depending on trans type and how you use the car.
Fact is, if you have a car that almost never sees the track, has an auto trans, and lives on Z-rated street tires, your stock rear will most likely last for as long as you keep the car, even at H/C power levels.
On the other hand, if you have an M6, you live at the track, the only tires you own are ET Drags... then yeah, you need to worry.
