torque arm adjustment help
i got a umi adj chassis mount tq arm for xmas. im going to install it this week, but my question is.......
what is the proper angle i should set the driveshaft?
also in what position does the car need to be in when adjusting?
is there anything else i need to be aware of when installing this?
car needs to be level
suspension needs to be fully loaded
I like to let the car sit on blocks overnight, to let the suspension "settle"
Check your transmission angle first... sometimes you transmission angle isn't always 0*. I know mine was -1*
I would set it on either -1 to -2 *. If you are a little more extreme, give it more angle. I run mine at -4*
You set the pinion, not the driveshaft. Take your angle finder put it on the Driveshaft. Write down the number. Put your angle finder on the bottom flat part of the torque arm where it mounts to the rear end. Write down the number.
Add the two numbers together. adjust accordingly
example:
If your DS was at 0* and your rear was at -2* then it would be a -2* pinion angle
0+(-2)= -2
each car can vary so initial numbers may be slightly off. End result you just want to be at around -2 for an automatic car street driven. I forget what manuals should be at
example:
0+(-2)= -2
Hello
Like mentioned above you want the vehicle level. And I usually suggest going with a -2 degrees pinion angle. If you have any questions feel free to ask and I will be more than glad to help!
Thanks
Brad
Thanks
Brad
example:
0+(-2)= -2
example:
0+(-2)= -2
Correct. IMHO to be done properly, you driveshaft should not even be in your car
This is the write up I learned from. It isn't f-body specific, but you learn a lot from it. After reading it you will be a pinion angle pro
Linky link
So, if you have a magnetic angle finder on the flat part of the torque arm mount, and the rear is pointing up towards the driveshaft, sounds like everyone is saying you have a negative number. But if you adjust it and the dial moves to the other side of zero, I now have a positive number?
Depending on your setup, you will want anywhere between 0 to -4.5*.
Thanks
Brad
ok so far i have gathered that the angle finder needs to be placed on the flat part of the rear end to get the angle. for the second measurement should it go on the ds or the transmission?
and when im adjusting the tq arm where do i put the angle finder while im adjusting?
setting up 4 street and strip 2 diff things
4 strip u are using the pinion angle 2 create lift on the front of the car for wight transfer... madman puts the car at ride height and then put the rearend -2 thats it
4 street i take the angle off the drive shaft and make sure the rearend is -1 from that angle..... -2 for a manual car
every car will be diff. because of the ride height if its lowered and so on
thats y u take the angle off the shaft first
thats the way i do it and its been working good 4 me
To tell you the truth it will be easier to explain over the phone rather than typing. So when you have a chance feel free to give me a call and I will be more than glad to help (814) 857-5400. I will be in the office M-F 8am-4:30pm EST.
Thanks Again
Brad
We have had this question hundreds of times and we decided to develop a video to help show the procedure.
I know you have a UMI torque arm but the procedure would be the same for all manufacturers.
