annoying squeak...need part number
Old 12-27-2009, 09:43 PM
r3adi7's Avatar
Default annoying squeak...need part number
ok, so my 98 formula has been making this horrible squeaking noise that increases with the rpms. We were trying to find the source of the noise and sprayed a little wd-40 on the crank pulley, which made the sound worse for a minute or so, then went back o the same shitty noise. So i'm guessing it needs replacing and i was wondering if anyone knows the part number. My oil pressure also fluctuates pretty sporadically and low at idle, so i'm thinking that its the oil pressure sending unit because the car runs perfectly fine, no knocking or anything. If I could get a part number for that too, thatd be great. Thanks!
Old 12-28-2009, 09:21 AM
2001NBMZ28's Avatar
The OPSU part number is 12559781 - make sure you get one for a '98, the '99-'02 sensors are different. You might find the other part number in the sticky for part numbers.
Old 12-28-2009, 09:46 AM
eseibel67's Avatar
Hold it! Not so fast. Squeaking caused by defective oil pressure sending unit is quite a stretch.
First revome the main drive belt and start it up. If it's quiet, buy a new belt. 5 minute job. If it's still squeaking, remove the pullies and grease the ball bearings.
Old 12-28-2009, 10:29 PM
r3adi7's Avatar
I'm not saying that the oil pressure sending unit is causing the squeaking...they are two seperate problems that need to be fixed. I need to replace the crank pulley because it squeaks, and the OPSU because im getting sporadic readings on my oil pressure gauge.
Old 12-28-2009, 10:53 PM
jsteele90's Avatar
check the belt before you do all the maintenance to replace the crank pulley!
Old 12-28-2009, 11:43 PM
r3adi7's Avatar
will do, thanks for the heads up guys!
