Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
carbertated smalll block in a camero
Old 12-27-2009, 11:54 PM
jhershaw1's Avatar
Default carbertated smalll block in a camero
will a carberated 350 bolt right in a 98 to 02 camero without having to change motor mounts and trany mounts
Old 12-27-2009, 11:55 PM
cookba's Avatar
dude you spelled Camaro, carburated and small wrong.
Old 12-27-2009, 11:58 PM
jhershaw1's Avatar
sorry my bad but would you happen to know about the question?
Old 12-28-2009, 12:17 AM
SanitysBane's Avatar
No it will not, either make your own motor mounts, get an aftermarket cross member with the small block mounts, or use motor plates. You will also need to trim the cowl to clear the carb and dent in the firewall to clear the distributor.
Old 12-28-2009, 06:22 AM
BassProCamaro97's Avatar
You won't need to dent the firewall.
You'll also need to figure out a new fuel system, trans, brakes, all your gauges, and accesories. You can get around some of this by keeping some of the stock electronics.
We need some more info on what your plan is for the car. It's not as easy as a straight motor swap.
~Jim~
Old 12-28-2009, 06:38 AM
deelong4002's Avatar
A carbed LS1 would be easier if you must be carbed.
