Fuse Blocks
Fuse Blocks
Hey im in the middle of a build of a twin car. I was wondering if anyone wants to share where they are moving the fuse blocks on the trans ams that is located on the drivers side behind the headlight? Pics would be great! Thanks
Anyone wanna share any info? I would like to run the wiring through the drivers side fender well like the wire tuck for the drivers side. All i know is i need to get those fuse blocks outta my way.
I moved mine into the wiper motor area. There is a ton of room if you don't run any wipers. You will just need to lengthen the wires to your lights up front which is not too bad.
