Anyone had their idle dip has you come to a stop?
Old 12-29-2009, 05:22 PM
onebadazzls1ta's Avatar
Default Anyone had their idle dip has you come to a stop?
How do you fix it does it have something to do with carbon buildup? My rpm's drop then pop back up when i come to a stop. I just would like to fix it LOL
Thanks
Matt
Old 12-29-2009, 08:34 PM
LS6427's Avatar
Could be a bunch of things.
Start by cleaning your MAF with MAF spray cleaner.
Could be spark plugs.
IAC valve could be acting up.
Put a can of MCCC through the top end to clean out the engine for carbon build up.
https://ls1tech.com/forums/general-m...-your-car.html
Old 12-30-2009, 05:45 AM
corvet786c's Avatar
I would agree clean your MAF, but be careful with those little wires inside. Get some spray. That will help it out a lot.
Old 12-30-2009, 08:43 AM
intense3123's Avatar
I had the same problem when pushing in the clutch to come to a stop. It'd dip down then come right back up to normal. Changed my spark plugs and it went away.
