Tranny cooler install pictures?
I seen a similar post and i need to know where your putting the cooler to add on the FTRA? I moved mine to the top of the radiator on the passenger side so i could route the FTRA but i was told the car will heat up more due to the cooler and FTRA blocking the radiator so now im looking at moving it somewhere else or would i still be ok leaving the cooler where it is?
Originally Posted by Ragtop 99
I have mine there. The car does run a bit on the warm side in the summer. The "Dope" method seems to work. Do a search and maybe you'll find the photos.
What is the Dope method? I did a search and came up with nothing.
