Ls3 turbo piston 10-12 psi ?????????????
Old 12-29-2009, 11:56 PM
chase3's Avatar
Default Ls3 turbo piston 10-12 psi ?????????????
Any idea's on which piston to run? LS3 block,stock stroke,6.125 rods,4.065 bore, AFR225 heads 64cc chamber's. Want to be 9.0 to 9.5 to 1 on compression. Will run 10 to 12 psi, 76mm turbo.
Old 12-30-2009, 02:19 AM
...with cheese.
Armageddon's Avatar
20cc dish will get you 9.0:1 assuming a .05 headgasket crush thickness.
14cc dish will get you 9.48:1
Old 12-30-2009, 07:09 AM
TT-TECH Veteran
Inspector12's Avatar
Yeah chase I had told your dad you would want a 15-20cc dished piston. The CR calculator is easy to find just do a google search if you want one to help you out.
Quick Reply: Ls3 turbo piston 10-12 psi ?????????????
