370 Iron Block (GM crank or aftermarket)
I am in the process of having a 370 iron block built for a turbo application and completely trust the builders knowledge, but I wanted some people to chime in that have the same set up. Will it be fine to use the GM stock crank that comes with the 6.0 iron block and save the $800-$1,000 on an aftermarket crank and put it towards good heads or something like that? Any PERSONAL
knowledge would be greatly appreciated, and what RWHP do you make with the stock crank? Thanks!
Stock crank here @ 737rwhp through a th400
Many guys have pushed the stock crank to 8's, but I bet that it will start flexing at this power level.
My goals are high 8's @ 3,200lbs, and I am not worried about the stock crank at all.
The stock L92's on the other hand......
Jim
Jim
I'm doing a GT88 turbo on a 364ci iron block setup with stock crank. Shooting for 1000rwhp and not worried about the crank. Get the main caps doweled/pinned to prevent them from walking around.
Plenty have been 1000rwhp+ without failure. To be honest with you it will be hard to find any postings on here about a failed stock crank in just about any application. Someone stuffed one in a twin turbo LSx race block setup and made 2000hp! It is on YouTube I believe.
