Drag Racing Tech - 1/4 mile vs 1/8
Shanna
12-30-2009, 08:53 AM
/ my car runs 8.20s at 91 with a 2.2 60 ft don't want to break the rear end. what kinda of time should it run in the 1/4 mile
buzz12586
12-30-2009, 10:51 AM
With that kind of mph in the 1/8th I can see it running 12.40-12.60's.
BlackScreaminMachine
12-30-2009, 11:05 AM
8.200 x 1.5555 = 12.751
This is considered the generally accepted calculation.
12-30-2009, 11:06 AM
MPH is not an accurate guage of ET's.
It is essentially a Weight Vs. HP ratio at best.
and based on that rule, I wager she has a 6 speed transmission and some bolt on mods.
buzz12586
12-30-2009, 12:55 PM
I under MPH doesn't gauge ETs. I am just saying that the car is going to backhalf a lot better than it front halfs.
When my car was a 6speed it ran 12.32 1/4 with a 7.98 1/8th on a 1.89 60ft
12.32/7.98 = 1.543
Now with the A4 it is 12.08 1/4 with a 7.66 1/8th on a 1.63 60ft
12.08/7.66 = 1.577
91mph is a ton of speed for an 8.20 1/8th mile time.
RARON455
12-30-2009, 04:03 PM
Yeah, that is alot of MPH for an 8.2 pass, especially with a 2.2 60ft. Normally a et of 8.20 would be around 84ish.
Shanna
12-30-2009, 05:07 PM
it does have alot of mods. i baby it out of the hole it is a m6.iam runing drag rad. if i launch it do you think i will break the rear end
tee-boy
12-30-2009, 05:42 PM
I always went off rule of .1 in 60ft is .2 in 1/4 mile and .1 in the 1/8th is .15 in the 1/4 mile. You could interpolate the ratios inbetween 330, 660 etc... But it isn't exactly linear.
Acceleration is a second order function (non linear). Velocity is a primary order function (linear).
RARON455
12-30-2009, 06:19 PM
MODS,,,,DRAG Radials,,,,, HMMM Lets say,,,, absolutely
especially with it being a 6 speed, one good clutch dump and you will need a tow truck.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
