ABS and ordering a rear end
I'm sure this is a dumb question, but I'm not fimiliar at all with rear ends and suspension. I am about to buy a new rear end for my car, but I have a 4 channel car so it will cost me extra to put that option on My car is not a dailey driver, but I do take it out and to work from time to time. If I order a rear end without ABS/TCS do I have to purchase a kit to get rid of my ABS, or can I just not hook it up and be fine?
i'm pretty sure that you need to remove your ABS/TCS if you get a non-ABS/TCS rear. SJM manufacturing makes a great delete kit you may need. if you dont remove the ABS/TCS and you install a rear without them you'll get all kind of faults and codes and warning lights...pretty much the same as if you delete the systems, but if you go the delete route you're brakes will work properly.
