317 valve question
Old 12-30-2009, 07:06 PM
Loudpipe's Avatar
Default 317 valve question
I bought a set of ported 317 heads with patriot 650 springs. One of the intake valves has the center of it sucked up into it. The retainer and spring are sticking up about 1/4" higher than the rest. The valve looks like you hit it with a ball-peen hammer right in the center of it. Nothing seems to be hurt but I am going to have it checked out. My question is would the springs have caused this and has anyone had a problem like this?
Old 12-30-2009, 07:13 PM
JPH
JPH's Avatar
Does the bottom/face of the valve look cupped?
Old 12-30-2009, 10:59 PM
Loudpipe's Avatar
yeah thats what i was trying to decribe.
Old 12-31-2009, 07:17 PM
Loudpipe's Avatar
anyone have any input?
Old 01-01-2010, 11:35 PM
Boosted One's Avatar
The spring did not caust that. That valve went through some trauma! Have them all checked, that is likely not the only one with issues.
Frank
Old 01-02-2010, 08:21 AM
JPH
JPH's Avatar
Detonation is what caused that!
Old 01-02-2010, 07:04 PM
Loudpipe's Avatar
Thats kind of what I was thinking. Massive detonation. The heads are at the shop getting checked out. thanks guys
Old 01-02-2010, 10:06 PM
1dirtybird's Avatar
Yeah I picked up a motor and it had two cylinders like that. They even put a hevier spring on it to try to get it to seal
Check the guides as the valve is bent, I am replacing the whole lot.
