RikkiTorment
12-30-2009, 11:45 PM
Doing long tubes and not sure whether I want to do the EGR/AIR delete. I've heard that I won't pass inspection without them, but the 01-02's didn't have them? Hearing that it's better to remove them, but I'm also hearing that I shouldn't remove them. Help, please? D:
PongoX11
12-30-2009, 11:48 PM
Well if you remove them you can have the codes deleted, removing them will only cause your car to fail the visual portion, which the long tubes will also do.
CrabhartLS1
If you're installing longtubes you're not passing emissions anyway, so why worry about EGR or AIR?
RikkiTorment
12-30-2009, 11:53 PM
True, true. The car is going to be exempt from emissions next year anyways lol
