What MAF do I use with 92FAST TB?
Finally my engine is coming together. I've got a 92mm FAST Intake and TB. What are my options for the MAF?My stock MAF seems way to small and would defeat the purpose of getting the bigger TB correct? If anyone can advise what they are using or what would work I would appreicate it.
Keep the stock one, theres more to an intake than the opening....
IF you MUST to change it, you can get a 100mm+ MAFs from many places, but that will require a tune. Right now you can just bolt on the FAST and go....fast....lol
Its going to need a tune anyway. I put in a comp cam, vavle spring, torque converter the intake and tb. If i can still use the stock MAF how do I make it fit to the 92mm tb just get an air tube to fit over the tb and then make the other end tighten down on the MAF?
You can do it and you will still see a gain. Though you will see more gains without the restriction. If you're doing a tune you can have a SD tune done and do away with the MAF all together.
sounds like that is the way to go since I'm getting the engine tuned etc..... any downfalls to getting rid of the MAF and doing the SD? I wouldn't think so if its being tuned out.....
Why would they hate me? A tune is a tune I would think. I've got to decide who is going to tune it. I've got two in my area. It would seem getting rid of the MAF would be the cheaper route cause the car is going to have to be tuned etc.....
