1998/1999 LS1 Throttle Body
Like the title says I need a 1998/1999 TB for ls1. Reason being I'm doing a swap and I'm using a 200 r4 auto tranny. Bow tie overdrives has a kit for the T.V cable that will only work with a 1998/1999 style throttle body(brown spring on cam), that's the reason it has to be a 98/99. Needs to come with the IAC and TPS!!! I also need some injectors. Stock 28Lbs are what I'm looking for. THANKS
