Boost controller recommendation
Id love an eboost2 but its not in the budget right now. Is there a cheaper electronic or manual boost controller that you would recommend? I was looking at the Turbo XS dual stage, its basically 2 manual boost controllers with an electronic actuator between them connected to a toggle switch. Any help is welcome?! You can always PM me non-vendor links also, thanks!
Forge
Ive got a practically brand new (FORGE) (UNOS) spring and ball type manual boost controler (in black) that i paid like $100 for that ide let you have for $50 shipped if intrested.I ended up just putting the bigger WG springs in a month ago on my APS TT
Turbosmart has the cheaper electronic controller out now.Eboost 2 is nice but is a bit pricey. You can as said go for manual ones for now they will work fine just don't give you some fancy options that the more expensive electronic ones can. Ams 500 seems to also be around eboost2 pricing I thought. I passed on the ams controllers as couldn't see where would mount them .The eboost2 is perfect in vents in the tas.
Barnats manual one sounds like a good deal for now for you. Then save up for nice electronic one down the road.
Restricted User
Save your money and buy the right one the first time. Rig up a manual until you have the cash. I run the AMS500 and it is super simple and super accurate. The down side is that you have to mount it under the hood because the MAP sensor is built into the unit and the longer the run to the sensor, the less accurate it is.
LS1Tech Sponsor
If you are looking for a cheap controller I would not waste my money on a junk turbosmart manual controller. Unless you like boost spikes, also no need for an expensive unit like an AMS unless you are looking to run some serious numbers.
McMastercarr.....get a low pressure air regulator and run it off the top of the gate. Rock solid boost with no spikes.
any chance you have part number and pix of the air reg you used from MCMASTER CARR??...They have tons listed.
the absolute best boost controller money can buy are called JS boost controllers, they are designed to out perform any boost controller on the market while costing a very small fraction of the cost. if you search youtube for JS boost controllers you will see demos and if you go to www.j-k-tuning.com you can order them, they sell for 50 bucks shipped for a single stage , 100 shipped for a dual stage that allows you to run wastegate on the first stage and a adjustable second stage and a dual stage for 130 shipped that allows you to adjust both stages. please dont let the looks of the design fool you, that was all done to keep cost very low while focusing on absolute perfect performance. i know over 15 people using this controller including my self and they work AMAZING.
msd has an electronic one for like 350 that u can ramp and also save tunes and re-load tham at a later date
ams-500 or ams-1000 if ur gonna be racing
i have used the aem tru-boost in 2 cars and thy work very good also with 2 boost setting and an off setting
essentially u have 3 boost setting but no rampng
both of the JS dual stage allow for a boost by gear set up however you need a way to trigger between the stages, most managements for hondas allow this to be done by RPM or gear and or MPH , i am still new to the LS1 stuff but i dont think the ECU can do it, your options would then be a RPM switch, a micro switch that gets triggered by the shifter being in certain gears, or a simple switch that you can activate or deactivate on your own. unless HP tuners allows the ECU to ground out puts based on MPH or gear like a honda ECU can.
sorry to hear, i have one of those laying on the work bench i could have gave yah, the problem with them is they use a bleeder for the second stage which severely limits the range of boost you can set between stage one and stage 2 . granted on a LS1 we dont run huge numbers of boost like the imports so this might not be as much of a issue.
