is there a HP to compression real of thumb
Old 01-02-2010, 10:14 AM
crazygn's Avatar
Default is there a HP to compression real of thumb
Say i run a head gasket thats a 4.15 bore and .053 think and my compression is 9.9 ...... And a 3.91 bore at .040 think is 10.35 compression
Is there a rule of thumb per .1 compression to HP
I run a ls7 head gasket now and was thinking about going with around about 3.91 x .040 gasket , now sure if the money to HP would even be worth it when the heads are off
Old 01-02-2010, 10:41 AM
TJ
TJ's Avatar
a point in compression is roughly worth 4% power increase. this is not 100% accurate.
if you make 400hp at 10:1 power output could increase 16hp at 11:1
Old 01-02-2010, 10:44 AM
BriancWS6's Avatar
Agreed
Old 01-03-2010, 01:01 PM
DSRE's Avatar
BUT here is where thats tricky, now that you bump up you compression you can now add a little more cam,head,intake which leads to Much bigger gains than 4%, I like getting max compression out of my builds as they always have awesome throttle response, better tip in, and better all around torque and drivability IMO
Old 01-03-2010, 01:46 PM
BriancWS6's Avatar
Of course you will increase power more than 4% when you add a bigger cam, better heads and intake along with more compression, but this thread is not talking anything about that.
All this guy asked was if there is a simple rule of thumb for power gains in relation to increasing compression which is ~4% per full point. What is the point in posting a bunch of off topic BS that can just confuse some people. I mean seriously.
Old 01-03-2010, 02:15 PM
BaddBird's Avatar
Im pretty sure he is trying to get his post count up.Back to the topic I would say 3-4% gain for a full point.
Old 01-03-2010, 02:33 PM
BriancWS6's Avatar
Sounds about right. I have been noticing a lot of BS posts here lately.
