So, I'm new to the LS1 world...
So, I've lived in the LT1 world for so long the only thing I know about LS1's is that I don't pair up next to them at the track, lol. Anyway, I'm about to pick up a 99 Trans Am. Its a NBM 6spd, t-top, leather car. The only modification that has been done is a flowmaster muffler which I intend to change. So...the only thing I know I will be doing is a Hurst Billet Plus shifter with the chrome handle and a black round **** and putting my TT2's from the LT1 on it. Aside from that I don't have the slightest clue what to do. I'm still unsure of what catback I want because I loved my gmmg when I had it on the LT1 but it was so loud with headers, and cam that it wasn't fun to drive any more. I couldn't hear the radio or have a conversation without raising my voice and I'm not really wanting that this time around. I was thinking about the magnaflow but never heard one on an LS1. So I'm open to any suggestions you guys have because I don't know a single person that owns an LS1 powered car (all my friends have LT1's) and aside from a catback (which I'm undecided on) and the shifter, I have no clue where to start. Also, its just a regular T/A so it doesn't have the cool hood scoops. I'd like to make it a functional ram air without changing the hood but I'm not sure if it can be done because there are no holes in the hood. Thanks in advance guys, I really appreciate your thoughts.
Chris
Chris
Well you would see good power gains with a ls6 intake and headers for around $600 then what ever the rest would cost for the cat back...also if someone hasn't done it yet and you don't get smog tested do an egr and a.i.r. delete mod
a good mellow cat back would be a magnflow. that's what i have with pacesetter longtubes and ORY and it sounds really nice, and you don't have to raise your voice to talk. take a look at the "so you wanna be fast" sticky up top and it would answer a lot of your questions as a ls1 newbe. didn't mean to sound like an ******* but some guys here post up stuff like this to be funny. good luck with your new ls1!
lid
LT's (whatever you have money for) ORY and IMO maganaflow is PERFECT for a DD.. It is very noticeable at idle and loud outside of the car while driving around but VERY VERY tame on the inside. At WOT it SCREAMS!
gears
ported TB
ls6 intake
tune
clutch
LCAs/TQ arm/SFCs
That should get you started...
gears
ported TB
ls6 intake
tune
clutch
LCAs/TQ arm/SFCs
Had it, not any more. Thought it sounded amazing on my LT1 but it was just too loud. My true duals are quiter than the gmmg. So a LS6 intake and headers. What's different about the intake? Also, I was looking at the slp flopack cai setup and I noticed that there were two different ones. One for the 98-00 and the 01-02. What's the difference? Also, my state doesn't have emissions or any inspection as a matter of fact so just about anything goes so long as the cops stay away.
Any other suggestions guys? I'm leaning towards the magnaflow with the quad tips. Also, was doing some searching for the difference in lids and really didn't find what I was looking for but I did find a really cool clear lid but read a lot of bad things about it. Does anyone know if one is made that doesn't have a cracking problem? One last thing, should I just get a lid and filter or should I get an slp flow pack that has the lid, filter, seals, metal tab, and bellows also? Thanks in advance.
I have the slp flo pac on my car, only reason I got it is because it was cheap used off of ebay. Most people say its a waste, just get a lid and a FTRA or something of the sort (fast toys ram air, just do a search). I have not had much experience with different lids and such, but from what I read, the SLP seems to fit the best (don't hold me to that, Mine fit like it was stock however), though it may leave 1 or 2 hp on the table compaired to someone elses or not look as cool, I would rather it fit good and not have to worry about it coming unlatched or not sealing like with some lids. As for the below, some people use a fernco from homedepot or lowes, with varrying results.
other than appearance...most lids are the same performance wise.
however...there are some out there that are bigger opening...like 100mm compared to 75mm. really won't make much difference since the MAF is 75mm and the TB is 75mm. also the dif between the years is in the location of the AIR inlet. earlier cars have it separate, later ones have it in the lid. minimal difference really.
cracking generally relates to those who put the stiffer bellow between the lid/maf and the TB. as the engine twists...it puts alot of pressure on the Lid...sometimes causing cracking. stick to the stock bellow and you're fine.
magnaflow is a great catback.
but if you really liked how the TDs sounded...why not go for that. great power, and great sound.
the SLP pac is generally overpriced. the lid and cai are the only worthwhile parts. and there are better ones out there (performing and looking).
the Fast Toys Ram Air (ftra) and the Super Sucker Ram Air (ssra) are the most popular cai.
LS6 intake is worth 7-10rwhp dyno proven over the ls1 intake. easy bolt on with minor changes to the coolant tubes. and the intake is always available used on here or ebay.
beyond that...jsut start reading around. take notes and ask specific questions. its hard to answer a post with general and vague questions on a multiple of topics.
enjoy the car
enjoy the car
Trunion King
Since it floods in AR, don't buy any CAI aka SSRA or FTRA. Just do the FRA mod, lid, stick w/ stock bellow, LS6 intake, descreen your maf or not, longtube headers, Y pipe exhaust system or true duals. For shifters, either go w/ hurst billet shifters, or the new fad, MGW shifters.
EDIT: I forgot to add, do a tune. LS1s are pig rich on stock setting. IIRC, mine was @ low 11s AFR.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Shifters and Catbacks: They are gonna vary from car to car. As far as shifters go I was most happy with my hurst billet plus over the factory hurst. Its not mushy feeling at all. Pick a stick that feels good in your hand. I didnt think I would like the stick that came with the Billet Plus because it was angled toward me. I will tell you one thing though, I never hit that brickwall going from 2nd to 3rd ever since I installed it. As far as catbacks go, if you have an exhaust shop near you that can do mandrel bends, design your own and pick your own muffler. Sounds like you dont want a loud car this time around, so I would get a chambered muffler like a Magnaflow or something.
I am in no way telling you to "not buy and SLP product" but you won't get the RWHP that they claim. Its only at the flywheel unless you have a factory freak bottom end with a 11.5:1 CR somehow.
Honestly, if I could go back to that cold November day in 2002 when I bought my HOSS I would have set aside money for an LS6 cam and a procharger. That takes care of more than half the stuff we are discussing in here. Money being a factor in that equation of course.
Most of us here have been around the block (literally) on the LS1,2,3,6,7 lowdown for nearly a decade, so don't hesitate to ask, heck, PM me any questions you have. I'm more than happy to help!
You may have been slow as an LT1, and I bet that 2.73 gear ratio wasnt helping you out much either.
