Which MAF's are 5 wire w/built in IAT?
Old 01-03-2010, 01:47 PM
jonathan_ed3's Avatar
Default Which MAF's are 5 wire w/built in IAT?
My engine didn't come with a MAF, so I'm looking at buying one. While searching I came across 5 wire vs 3 wire. 5 wire seems the way to go.
What vehicles should I be looking in for the 5 wire MAF? Is it true that these have a built in IAT?
Are the 5 wire MAF's 3.5" or 4"?
Are all of them the same? Truck, car etc?
If it matters, I need one for a '98 LS1.
For the "SEARCH" guys: I tried searching but the search feature on any VBulletin forum is very rudimentary and doesn't necessarily return relevant results.
Old 01-03-2010, 02:44 PM
Rubidon's Avatar
Does your wire harness support the three wire or the five wire? My harness came from a '02 silverado and it has a five wire hook up,as for the size I am in the dark also. The five wire has a built in IAT.
My TB is 4"
Old 01-03-2010, 04:29 PM
My wire harness is for the 3 wire MAF. But I can make or purchase a harness to include the IAT wires into it which makes it the 5 wire unit. I like the idea of the all-in-one MAF unit to simplify my intake routing.
Old 01-03-2010, 05:01 PM
poconojoe's Avatar
The LS based truck MAF are all 5 wire, a lot of times you can find new ones on ebay for under $50
Search for part # 25168491
Old 01-03-2010, 06:01 PM
Thanks for the help.
Do you know if that part number will work fine on a mostly stock '98 LS1? I assume so, but I'm pretty new to these LS engines so just want to make sure.
I have to buy one regardless, so would be nice if I could use the one with a built in IAT.
Old 01-03-2010, 06:38 PM
poconojoe's Avatar
Most likely you'll have to change the tables in the PCM for it, since I think its bigger then the stock 98 MAF
Quick Reply: Which MAF's are 5 wire w/built in IAT?
