FAST intake
Old 01-03-2010, 06:31 PM
Goldcuffs's Avatar
Default FAST intake
Hey guy's, can I use astock T/B with a FAST 92 intake? (temporarily)
Old 01-03-2010, 06:40 PM
garygnu's Avatar
a fast 92 mm intake is 4 bolt.is you engine a ls2 with a 90mm intake?,which is a 4bolt TB.
Old 01-03-2010, 06:45 PM
Mean87SS's Avatar
Assuming since hes in GENIII, No.
Old 01-03-2010, 07:03 PM
Goldcuffs's Avatar
correct, 2000 LS1
Old 01-21-2010, 09:18 PM
LUISP's Avatar
Originally Posted by goldcuffs
hey guy's, can i use astock t/b with a fast 92 intake? (temporarily)
that stock t/b wont work bro.
Old 01-21-2010, 09:26 PM
Red99TA's Avatar
Just wrap it in some kentucky chrome - it'll be alright.
Old 01-22-2010, 06:42 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Nope, does not fit.
Old 01-22-2010, 09:12 AM
MonmouthCtyLS7's Avatar
Stocks a 3 bolt piece, Fast uses a 4 bolt.
Old 01-23-2010, 03:39 PM
Chris10an's Avatar
You can buy an adapter for Ls2 to Ls1 TB. That should get you on the right way. i don't dear to post a link to the product, but you find your product if you search for it.
Chris.
Old 01-23-2010, 04:01 PM
Chris10an's Avatar
her's the pic of it
Old 01-23-2010, 06:51 PM
garygnu's Avatar
I was just looking at my fast 92 intake.It has a hole center/top of the intake opening.take a ls1 TB and see if the TB bolt holes line up with the bolt holes of a fast 90/92 intake.
Old 01-24-2010, 10:42 AM
NOS327's Avatar
yeah, I always thought they were dual patterned.. what is that top hole for?
Old 01-24-2010, 04:43 PM
garygnu's Avatar
has any body taped the rear coolant passage on the head and run coolant lines over the intake when running a fast intake?
Old 01-24-2010, 05:02 PM
Silver408z's Avatar
Your pic is probably a fast 78 mm. The 78mm would match a ls1 tb
Old 01-24-2010, 05:12 PM
1999BlueTA's Avatar
Nope it says 92mm on the intake in that pic. I've always noticed the hole center/top on the FAST 90's & 92's and wondered what they were for but I don't think they are designed for LS1 style 3 bolt TB's.
Old 01-24-2010, 06:53 PM
SweetS10V8's Avatar
It cant work, the bottom two holes on the 3 and 4 bolt have different spacing.
Old 01-26-2010, 06:58 AM
Originally Posted by Chris10an
her's the pic of it
Funny I made a post asking if there was one of these mths ago and I got no replys
Old 01-26-2010, 07:05 AM
deelong4002's Avatar
The fast 90/92 definately has 5 holes (i only use 4, cause only 4 are tapped), but they are not the same pattern as the stock throttle body. The top hole would require a jam nut on the back side.
Old 01-26-2010, 07:06 AM
BTW my Nick WIlliams throttle body, has a 5th hole on it as well, if i wanted to run the 5th bolt
Old 01-26-2010, 09:17 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
You'll have to run a 4 bolt tb or buy a adapter that isn't terribly cheap. We're putting together a PTM TB & Fast intake combo special right now. If you need a PTM tb give us a call, I'll get you a great price on one!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
