Pac 28-1518 valve springs
Old 01-04-2010, 08:55 PM
crazygn's Avatar
Default Pac 28-1518 valve springs
Is it true you can run these springs with you stock locks and retainers and run up to a 650 lift cam, or say a ms3 or ms4 cam
Item Detail
Name:
PAC Single Beehive Valve Springs
Item#:
28-1518
The PAC single valve springs will use your factory seats, seals, retainers, and locks! We recommend stepping up to a dual valve spring kit if you plan to run more than .650" lift.
Old 01-04-2010, 09:03 PM
Tom@SpeedInc's Avatar
That is correct, however for over .600 lift I'd rather use a dual spring
Chris O or Allyn at Pac would agree.
Pac sells dual springs too.
http://www.speedinc.com/cont.cfm?cid=C0000919
1518 springs are on backorder till February btw.
Old 01-04-2010, 09:50 PM
01ssreda4's Avatar
I agree with speedinc on this one. Just bc they can handle .650 doesnt mean they are right for a cam with a .640 lift.
Old 01-04-2010, 09:51 PM
crazygn's Avatar
so as long as i stay under .600 lift i will be fine with these springs
It says there good for .650 lift so are you pushing your luck or something with these, and the duals would have no problem. Crazy they would rate it that high if you really should not run one that high
thanks for the info
Old 01-04-2010, 09:56 PM
crazygn's Avatar
ok , i'am not set on a cam and spring yet so maybe i'll say up some more money and do it right the first time. I was thinkin about something in the 580-590 but who knows right now
Old 02-03-2010, 09:02 AM
99_SS_LS1's Avatar
a late reply but I run these springs with .609 lift. No problems, and I have heard nothing but good about these springs.
Old 02-03-2010, 09:15 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
For the MS3, I like the PAC 1518 just fine! They are light weight, strong, and have a strong record of success.
For the aggressive intake lobe on the MS4, I'd recommend the PRC EHT .675" lift spring kit. The EHT chrome silicon makes for a longer life with these aggressive high lift lobes as compared to the standard .650" spring kits available, and give you a little "wiggle room" on the lift before coil bind!
We offer both (and have them in stock) at competitive pricing, and would be happy to earn your business! Let us know if we can help!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 02-03-2010, 09:16 AM
LS1Tech Sponsor
Beau@SDPC's Avatar
We have 17 sets on hand, good thing we buy in bulk. The sell point about these springs are a) they are nitrided b) they are proven c) they are made by pac d) they are inexpensive 5) you do not have to buy seats, seals, locks (super 7), or retainers to make them work.
Old 06-08-2011, 12:42 AM
GIGAPUNK's Avatar
What rate are the 28-1518? Seat and open pressure?
Old 06-08-2011, 08:17 AM
Darkman's Avatar
Open = 318 , Closed = 130, Spring Rate 313.
Old 06-08-2011, 10:19 AM
Always give pressure at the corresponding height, otherwise the pressure doesn't mean much!
1.800" = 130 lbs
1.150" = 333 lbs
Spring Rate = 313 lbs/inch
Coil bind = 1.080"
http://www.racingsprings.com/Multime...talog_2011.pdf
__________________
Old 06-08-2011, 10:59 AM
Mart00SS's Avatar
Everyone says all of the beehive springs are a direct fit on your stock spring seat, but to me this is not true. The Inner diameter at the base of an aftermarket beehive (name your brand) is .885 and the ID at the base of a stock springs is .850". The stock spring locator measures about .840". I know people just drop these springs in and go but For me this was way too much lateral movement allowed at the base of the spring. The only spring locators I could find that were for a .050" guide and .885" spring were Ferrea's. Check out this thread...
http://www.yellowbullet.com/forum/sh...d.php?t=330283
Old 06-08-2011, 11:12 AM
2000ws6transam's Avatar
bout to toss them on my car in 30 min i ran the stock LS6 springs with a cam @ .010 below the rating. I would think if a vendor says its good for .650 lift they have weeks or years of testing to verify the statistics. im just doing .570 lift but i wanted the pressure to keep good control of the valve with fast ramp rates. I only wish cam makers would give us more info for spring pressures Vs. acceleration rate vs lift!
Quick Reply: Pac 28-1518 valve springs
