370ci, rear mount - suggestions?
Old 01-05-2010, 08:45 AM
sujomatt's Avatar
Default 370ci, rear mount - suggestions?
Well I decided I want more power, was thinking of going front mounted turbo with the build.. But I feel like the easiest thing to do is to use the stuff I already have.
My current setup is in my Sig.
Currently I have a T67 .81a/r STS turbo system on a stock block
I am probably going with a 370ci lq9 from Speed Inc (will try to pick up some ported heads as well)
Going to be picking up a turbo cam spec'd for the build too..
What size turbo would feed this the best? - was thinking a T78 would be sufficient..
Will the charge piping be large enough and the IC core of 3" be big enough?
Will 60 lbs injectors be enough with the use of Meth injection? - i'd assume no, and id also assume i'd need twin pumps, or some other pump (please recommend)
Hope this isn't too much to ask - just don't want to start a build and realize im *** backwards lol
Thanks
Old 01-05-2010, 09:21 AM
LS1TECH Sponsor
DrTurbo's Avatar
For a rear mount for big power,most are going with the TC series units. The TC76 and TC78 are where its at. Big power and same packaging as the 67 almost other then the inlet.
Old 01-05-2010, 09:25 AM
TurboAv's Avatar
You could always run new 2 1/2" charge piping from the turbo to the intercooler. If I remember correct STS comes with 2 1/4". Then jump it up to 3" as soon as you can when you get close to the intercooler. On the outlet of the intercooler go 3" into the engine bay then jump it up to 4". 80# should be good for about 900flywheel hp if you use the RC Engineering injector calculator where you don't go above 80% on the duty cycle. There are also 103# high impedance injectors also. http://fuelinjectorconnection.com/sh...ewCat&catId=73
The TC78 with a .96 would be a good match. Just my opinion though. Finally, yeah you will definitely need more fuel. A do it yourself twin pump with a return would work great.
Good Luck.
Old 01-05-2010, 09:30 AM
hawk584's Avatar
a buddy of mines '02SS with a forged LS1 with the same turbo specs you have is making over 630rear wheel on 100oct. fuel in vegas
Old 01-05-2010, 09:50 AM
sujomatt's Avatar
Thats awesome thanks for the info Dr - I will be PMing you when I am ready to pick one up!
Good Luck.
I like that idea! I just need to find a FMIC setup that will do this for me haha. I always see 2.5" inlet and outlets
Yea my goal on 93oct and meth with this is 750 or higher lol
Old 01-05-2010, 10:11 AM
TurboAv's Avatar
Here's a 32x12x3.5 with 3" inlet/outlet for $75
http://cgi.ebay.com/ebaymotors/32-x1...item27aa0a8815
31x11.75x2.75 with 3" inlet/outlet for $68
http://cgi.ebay.com/ebaymotors/31-x1...item1c0e03ce36
CX racing 31x12x4 with 3" inlet/outlet for $119(my favorite of the 3 listed)
http://cgi.ebay.com/ebaymotors/CXRac...item25581c72f0
Old 01-05-2010, 10:18 AM
sujomatt's Avatar
SICK! I have a CX Racing FMIC now but its just not big enough to support this. Thanks for the quick help man!
Just ordered it!
Old 01-05-2010, 11:02 AM
sujomatt's Avatar
Any recommendation on Fuel Rails? Fuel line sizes? just grab a FAST rail to match the intake manifold I have?
Assumingly I'll require the boost referenced regulator - correct?
Would a BOSCH 044 Inline pump and a walbro 255 in tank do it?? Still have the hotwire and boost-a-pump nonsense.
Damn I suck at this lol - new things make me ask a million questions..
Old 01-05-2010, 11:23 AM
dschmittie1's Avatar
I would run the lonnies dual intake pumps. I did the DIY dual intanks and ran a 8AN feed and used the stock feed as a return. I am running Speed inc rails on mine and I am about to the limits of my 60lb injectors at 670 rwhp with METH.
And as I said before in your FS thread. When you wanna sell that cam you have now let me know.
Old 01-05-2010, 11:24 AM
PS I am running a Boost Ref FPR. It helps make injectors go farther.
Old 01-05-2010, 11:41 AM
sujomatt's Avatar
Yea it's yours once it comes out!
I am looking at the Lonnie's kit now on their website. Looks like they have a full setup for 1600 .. includes everything necessary! (even the FPR)
"Double Pumper Kit & Complete Custom Fuel System
Camaro/Firebird '99up LS1 Double Pumper - Twin High Output Fuel Pump Kit, Wiring Harness & Hobbs Switch - Fully Assembled & Tested - Requires your sending unit for modification" - with 80lbs injectors!
Old 01-05-2010, 02:34 PM
sujomatt's Avatar
The 317 heads - what are some good replacement valves? I figure I should upgrade them since I was planning on using the heads for now.
Old 01-05-2010, 02:45 PM
stock valves will be good for awhile. the only reason I would replace is if you went the heads out and had larger valves installed and had them ported.
Old 01-05-2010, 02:55 PM
LS1Tech Sponsor
Superman09's Avatar
Wait for Zombie to get in here or send him a PM. He is the man you want to talk to about a rear mount set-up and he runs 370 cube iron block as well IIRC
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 01-05-2010, 03:01 PM
Bryan @ Speed Inc.'s Avatar
on the cam specs and motor combination, feel free to call or e-mail us.
Old 01-05-2010, 03:17 PM
Yes, you'll want a boost referenced regulator. also - check out our rails. they're similar to the FAST but are less expensive.
http://www.speedinc.com/cont.cfm?cid=C0000051
Old 01-05-2010, 05:11 PM
sujomatt's Avatar
That poor guy is probably harassed everyday haha - If i run into anything ridiculous in the build I'll definitely contact him though! lol
Definitely going to be contacting you guys soon!
Sweet, I think I'll be grabbing those as well
Old 01-05-2010, 06:06 PM
hawk584's Avatar
does NJ have E85?
Old 01-05-2010, 06:07 PM
sujomatt's Avatar
does NJ have E85?
NJ? Why New Jersey? lol - no idea
was that a hint the power i want is not gonna happen? haha
Old 01-05-2010, 06:24 PM
hawk584's Avatar
my bad, i ment CT, no hint at all, i don't know the limits of 91 or 93 oct is all... i think i'v seen somewhere on here people tuning for E85 and getting some nice numbers
on my little forged LT1 on 91 i'm just over 500rear wheel on a onetime mailorder tune
Quick Reply: 370ci, rear mount - suggestions?
