New LS1 Owners - Newbie Tech - what are the specs on a zo6 cam?
jpbgto
12-18-2003, 07:26 PM
what are the specs on a zo6 cam? I have seen a couple in the parts for sale section. What kind of rwhp can I expect with stock heads? thanks
jim
BlackTA
12-18-2003, 07:43 PM
You won't gain as much as you would with an aftermarket cam, but if you buy a used one it will definitely be excellent bang for your buck.
what year; the 01's are different then the 02+.
01: 204/216 .525/.525
02+: 204/218 .551/.547 117.5 lsa
you'll mostly see more power in the top end 4k+. i say you get a better exhuast setup and look into another cam.
CamaroSS
12-18-2003, 07:53 PM
And it is covered under warranty too :D
Then again my friend has the X1 cam and the dealer has no clue....he just raises the idle to 1,200 before he takes it in. ;)
onebadz
12-18-2003, 08:30 PM
I could see someone gaining 15 RWHP with the LS6 cam...if you want a good all around cam you should look at the TR(thunder racing)224. Good Luck
Wes
jpbgto
12-18-2003, 08:48 PM
thanks for the help
CamaroSS
12-18-2003, 09:16 PM
Unless you can get the cam for around $100 then it isn't worth the money nor the time to put it in.....trust me.......save for a better cam, you can see gains around 15-20whp on certain set ups, and more on some.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
