Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
c5 z06 should i go wit c6z clutch or c5z
Old 01-05-2010, 11:31 AM
c5z16z's Avatar
Default c5 z06 should i go wit c6z clutch or c5z
is it possible with out any problems on install a c6zo6 clutch in my 04 c5 zo6
or should i go with the stock c5 zo6 clutch?.... and the same thing with the shocks can i put the c6z06 shocks in my c5 zo6 or should i just put the stock c5 zo6 shocks or what other shocks are as good or better that are around the same price? what do u guys think?thanks for the imput.........
Old 01-05-2010, 01:29 PM
03Sssnake's Avatar
I have the LS7 clutch with LS2 flywheel in my 01 Z/28 and the Monster Stage II in my C5 Z06. The setup LS7 clutch package from SDPC is a great deal, however if you have plans for more power in the near future, you are better off with something else. I like the monster, however, it is a very grabby clutch. You will have more chatter than with the LS7 or LS6 clutch. In regards to the shocks, I would like to find some 04 Z06 shocks, those were the best ones out of the C5Z years. Since you already have them, why change? I have heard of guys using the C6Z shocks, but I am on the fence. The C6 is a little heavier, has bigger wheels and brakes, so they were really tuned for that car.
Old 01-05-2010, 02:40 PM
c5z16z's Avatar
that monster sounds good but i daily drive my c5z so i wnt something i can drive good in traffic and that does not make a lot of noise i only plan on bolt ons for now till i get a c6z so would the ls7 clutch be good for a daily driver? and is there any problems with the install?......i asked about the shocks because i plan on putting new ones in but dnt kno what to put in because my c5z sits about 1.00" lower on the passenger rear side than from the driver rear side what do u think the problem might be cuz my bro has a c5z2004 same year and it sits perfectly even so thats why i wanna swap out shocks thinking it would solve the problem what do you think?
Old 01-05-2010, 02:53 PM
03Sssnake's Avatar
In regards to your ride height issue, that could also be your front or rear spring. Check and make sure the bolts/nuts are adjusted to the same level on all 4 corners. FWIW, I daily drive the Z06 and the Monster clutch chatter is no longer much of an issue, it is well broken in now and I made some adjustments in my driving/clutch pedal engagement.
Old 01-05-2010, 10:05 PM
c5z16z's Avatar
my c5 z does not have springs it only has shocks ...and what nuts and bolts are u talking about adjusting for the height?
Old 01-06-2010, 12:20 AM
03Sssnake's Avatar
the spring is one assembly, not a coil spring, a leaf spring. The bolts are at the ends of the springs..
Old 01-06-2010, 08:36 AM
c5z16z's Avatar
thanks man..... so is that means that my shocks may not have to be replaced ..... ill try to get under the car to adjust them in my garage or on some ramps.... also i was looking into that monster clutch you have in your c5z but you said u have the level 2 monster is it heavier than the stock and would you recomend the monster level 3 instead of the level 2 ? also did yo have any problems on instal on the monster level 2.. and is it working fine any down sides about it?................and what d you mean by more chatter and grabby does it make more noise ?
Old 01-06-2010, 08:43 AM
03Sssnake's Avatar
The Level II Monster is more than sufficient for bolt-ons, cam and heads. I don't have current plans to go beyond heads and cam. The engagement can be rough, but it gets better once broken in and you learn to drive it. A shop did the installation..
Old 01-06-2010, 08:59 AM
Z06ME's Avatar
Another clutch option would be the Centerforce Dual Friction. Price is good, reviews are good, and it will handle some additional power.
Old 01-06-2010, 11:51 AM
c5z16z's Avatar
thanks guys that sounds good cuz i plan on doing the same thing heads cam intake bolt ons what do u mean by rough is it heavier do u have to push the clutch pedal far down for it to engage?....and about how many miles did you drive it with out ******* the car for it to break in?
Old 01-06-2010, 12:17 PM
03Sssnake's Avatar
Clutch is easier to push in actually. When the clutch was engaged it was a bit jarring at first, till it was broken in and I adjusted clutch engagement. You really can't slip these as much, they want to grab right away...
Old 01-06-2010, 02:37 PM
c5z16z's Avatar
what did you purchase with the monster level 2 clutch in your c5 z what fly wheel did u use? and how much to install it $??...
Old 01-06-2010, 07:49 PM
BlownVette 2001's Avatar
On the front springs you'll need to use a jack to relieve the spring pressure so that you can turn the adjuster nuts. Each turn is equivalent to 5/64"
Old 01-07-2010, 10:23 AM
03Sssnake's Avatar
Monster clutch level 2 package included flywheel, and pressure plate for around 650.00, and the install was 600 (Pavlock Performance). The package should also come with a slave cylinder as well..
http://www.monsterclutches.com/level2clutch.html
Old 01-08-2010, 09:30 PM
c5z16z's Avatar
well im getting ready to buy my clutch what should i go with i have a 2004 c5 zo6 with a diablo tuner,vararam vr-b2,vararam power duct,and borla "stinger" cat back for NOW!......... and i PLAN TO do heads/cam/intake in the future i wanna know whats a good daily drivable clutch i do not want it to make chatter noise i and i want it to last...... also for it to work with what i have now in the car (diablo tuner,vararam vr-b2,vararam power duct,and borla "stinger" cat back) i was thinking the monster level 3 what do you guys recomend for good daily driving????? thanks ...........
Old 01-09-2010, 01:38 PM
bloodhoundz28's Avatar
i would highly recommend you choose the monster clutch level 3.I had a spec3plus which was brutal for daily driving however i put a monster level4 and couldn't believe how soft the pedal was and perfect for daily driving.
Old 01-09-2010, 09:27 PM
c5z16z's Avatar
what about noise wise any chatter at all after break in i dont want a noisy clutch?
Old 01-09-2010, 10:03 PM
scramblerman's Avatar
do it right the first time, get a ram twin disk.
Pedal is just like stock, and is great for daily driving. Will hold more than enough power when you do the h/c/i package on it. There was some chatter on break in but it went away.
Old 01-10-2010, 02:35 AM
chatter isn't bad and none at all in reverse.this may sound crazy to you but every since I put that Monster clutch in my car I haven't been able to stop driving my car.I installed the clutch friday and already have close to 200 miles on the clutch all stop and go and it feels stock at the pedal thats a trip but a little chatter in first gear and that to is just about gone.Monday I'm taking my car to LMR to have my patroit heads installed clutch should respond well to extra hp with no problem.
Old 01-11-2010, 03:55 AM
SStheBest's Avatar
sense you plan to go with H/C you better opt for the stage3...or else you chance goin back in there for another clutch down the road. Thats why most will opt for the better clutch to hold the power for the future mods.
Quick Reply: c5 z06 should i go wit c6z clutch or c5z
