Need some help installing the Tick MC linkage between clutch pedal and MC
Alright, everything else went in like butter, but now I'm having some difficulty for some reason. It seems like the turnbuckle that goes between the MC and the MC and the Clutch pedal is hitting on this piece that I circled, not allowing the turnbuckle to get low enough to link up with the clutch pedal. Am I missing something? Did anyone else have this issue?
Thanks
Thanks
Can you get the tierod end thing on the top to slide all the way on? I couldnt, had to lengthen the rod a bit. Mine was hitting too, coudltn figure it out, once you slide it all the way on it wont hit.
