Installing a BBC carbed into 01 TA????
Old 01-05-2010, 09:19 PM
WS6 Canada's Avatar
Default Installing a BBC carbed into 01 TA????
How do I remove the fuel injection out of my TA and still have all the interior stuff working....locks, windows, lights, etc.
Thanks
Old 01-06-2010, 09:10 PM
zeekracing's Avatar
You should be able to do some searching on hear to find out the major stuff. I know most people that go bbc are building race cars so it may be hard to find out. The main thing is to use your factory sending units on your motor and get a full wiring schematic for your car and try to relax. You may have to run a few hot wires to the sending units becuase they are not connected to a pcm. Depending on your trans will make the differance on your speedo. You will have to find some kind of a signal convertor for your tach becuase I belive these computer cars put out a 4cyl signal so if you hooked your factory tach up to a old school coil it would read twice as much.
