exhaust size
exhaust size
i ran a 2.5" Flowmaster setup all last year with the Procharger/6.0, but now i have the stroker, AFR 225 heads, EPP cam, wonder if a switch to 3" would yield much-its in an A body, true dual exhaust
not sure what size the Vette/Camaro guys are running
Did you change the pulleys on the procharger? If not then you'll be making less boost with the new setup and close to the same power levels as before. If you're pullying up then definitely go bigger on the exhaust. What power were you putting down? Which procharger?
Definitely do a 3" or even 3.5" with a bullet (straight through) type muffler and no cat if possible. I'm running 3.5" duals with my procharger setup
