Did LQ4/9 head bolt questions...
LS1Tech Premium Sponsor
Yes, they got the change over in '04 as well
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
If the gasket is MLS it's not going to burn it. The only thing mix matching parts like this is you need to make sure the compression part of the gasket is between the head and deck surface to provide a seal. Heck I'm probably going to use the LS3 gaskets on my 4.005" bore TFS235 head motor even though the LS3 gasket is 4.065" just so i can make use of the 5 layer gasket vs the 3 layer of previous years. Havent really decided yet.
After rethinking this situation a 6.0L gasket would probably need to be used since the bore is just over .100" difference between 5.7L and 6.0L. The head might not seal using the smaller bore gasket on a bigger bore head.
Better to have all one size (late block) for consistent torqueing, but it really makes no difference in the long run.
