PTV Help!
PTV Help!
What is the Safest-Shortest distance I am able to have for a Piston to Valve Clearance? I am trying to use a stock 5.7 ls1 and 317 heads they have work done not sure about how much it has been milled. I have a Trex cam
.608 .612 lift 238 242 Durat.
most people would recommend .080 IN .100 EX.
i dont think there is a max "safe" clearance you are looking for. rpm and valve timing will play their own role as well.
is it an automatic or manual transmission?
Here you go if you don't know how to do it yet. by the way .080 is the best distance.
http://www.racingheadservice.com/Inf...eClearance.asp
