pathology knight
01-06-2010, 09:39 PM
Not sure which section to put this.....
my driver's side headlight is driving me crazy.
a while ago it stopped working, meaning it quite going up and down. The actual light is fine.
i did some checking and the most common problem is the little gear inside craps out. Mine didn't make any sound or any grinding noise or anything, so i decided it wasn't the gear. I checked the fuses, and everything was good. I went ahead and bit the bullet and bought a new motor. during testing, i could see the new one was getting power and was working. just to be sure, it tested the old one and still nothing. I put the new one in and it was fine...sort of.
Every now and then it wouldn't work. it either wouldn't go down or wouldn't go up. I remember seeing how the terminals were a little corrodid (sp?) when i put the new one in and thought maybe the connection was bad.
All week it's been giving me trouble, not going down, so i finally took it apart last night and "cleaned" the terminals. i checked the fuses again and everything was good. i also noticed that the bottom of the "arm" that connects the motor gear to the headlight assembly was just barely rubbing the bottom bolt that holds the motor in place. i took it out and added a couple washers on teh bolt's head side to "suck in" the nut. It clears it with no problems now.
It still doesn't work right. Today when i got off of work, it didn't come up! I got out and manually cranked it up. when i got home, it went down with no problems.
Any idea what's going on?
