Water in Catch can?
Old 01-07-2010, 12:23 AM
whiteseven's Avatar
Default Water in Catch can?
Is this common if you make a few short trips without letting the engine warm up?
I just cleaned my catch can and then moved my car out of the garage, washed it, moved it back into the garage, polished/waxed it, then moved it back outside to sit for a little bit. Drove it about ... 20 miles round trip then parked it back in the garage. Opened the catch can a day later and it had about 4 ounces of water (NOT coolant) sitting in it, and no oil.
Common issue with short trips? It's also been extremely cold here the past few days in florida. Like 30-40 degrees.... Wtf?
Old 01-07-2010, 02:20 AM
DSkyles's Avatar
lol extremely cold is 30-40 degrees huh? It's supposed to be single digits in St. Louis tomorrow.
Old 01-07-2010, 07:17 AM
BIG_MIKE2005's Avatar
Yep, your suckin the condensation into your catch can. Normally once it gets to operating temps that stuff evaps off. But you'll also notice on those short trips your oil cap will have a milky residue on it as well & its the same thing. Just not getting hot enough to burn out the water vapors from sitting. This might not happen with a catch can since you found water in yours. Sounds like your can is doin its job but with your short trips its pickin up the water vapors instead of oil vapors.
Just my opinion.
Old 01-07-2010, 07:26 AM
530sx's Avatar
^^ I always wondered what that nasty residue was on my oil cap!
Old 01-07-2010, 08:04 AM
whiteseven's Avatar
I live in FL man, it should be 65-70 here on average highs.
And thanks mike, that makes sense.
Old 01-07-2010, 09:15 AM
techrunner's Avatar
30-40, i'd be in shorts. its 18 below here right now.
Quick Reply: Water in Catch can?
