converting a carb plate kit to ls1 dry
Old 12-19-2003, 12:25 AM
AINT SKEERED's Avatar
Default converting a carb plate kit to ls1 dry
I am getting a cheater nos kit from my brother but I am just going to put the nitrous silenoid on spraying a dry into the mass air. What is the correct jet for a 50 shot and a 75 shot through a single nossle? This is as big as I want to go and untill I get a bigger fuel pump and injectors I am going to stay with the 50 at 900 psi bottle pressure. Just a little extra help to sneak up on a freind
I am going to monitor everything on a scanner to make sure it dont get lean. Thanks for any help in advance.
Old 12-19-2003, 12:40 PM
ttt ANy body know if this will be ok? I can leave it a wet kit as well just buy the right nossle.
Old 12-19-2003, 12:43 PM
4thGENRETARD's Avatar
0.037 dry single jet= 50hp
0.042 dry single jet = 75hp
Just keep in mind not to shoot too close to the MAF as N2O is super cold and u can run the risk of freezing it.
Old 12-19-2003, 12:56 PM
Thanks, I am going right in above the air filter on the under side of the air lid. I have a few freinds running this setup and it is hidden pretty well.
