-8 hose for breather tank?????
What hose is best for a breather setup from the valve covers? Im using two factory driver covers with -an fittings welded in them. The breather tank has 3/8 npt ports. Would -10 be overkill for those ports or would -10 be the best to use?
I agree with the -10 but don't believe the 3/8" NPT fittings will support a -10. There will be a stepdown in the NPT/AN adapter that will effectively make the -10 a -8.
So you either need a different breather tank or I would go with two separate -8 lines. Otherwise you are wasting your money on -10 fittings and hose while still dealing with a -8-sized hole.
Jim
Jim
Is it enaugh with just a breather tank? I ment i read that i needed some kind of vacuum. Even when im in boost.
Do you guys mean that its neccesarily to have two seperate -10 lines to the tank?
EDIT: the thread below answered my question =)
