Can't get stock y off...
Old 01-07-2010, 05:07 PM
Gordo78's Avatar
Default Can't get stock y off...
Aight i'm getting pissed. Any tips on getting the factory y-pipe off at the intermediate pipe? I can't get the y and the I'pipe apart. I cut the bolts on the manifold flanges so thats off, and undid the clamp in the intermediate pipe, and it still won't come off. I've soaked it in PB blaster, and have spent the last few hrs letting it soak, and beating the **** out of it with a hammer towards the front, it won't budge.
Old 01-07-2010, 05:09 PM
badss_02's Avatar
Get all the panther **** off of it and heat it up with a torch... It'll come off it is just a pain in the ***...
Old 01-07-2010, 05:10 PM
hlaalu's Avatar
sawzall!
Old 01-07-2010, 05:11 PM
Gordo78's Avatar
Don't have a damn torch... FML
01ssreda4's Avatar
Get an exhaust pipe disconnect tool. They are cheap. It squeezes the two sections, then you tighten it to spread them apart.
Gordo78's Avatar
Originally Posted by hlaalu
sawzall!
Lol thats what i've been using, but i'm installing a y-pipe in a few weeks, so i really need to get it out to install it on my catback.
Old 01-07-2010, 05:13 PM
getsum27's Avatar
the clamp is what has crimped it some
if i were you i would go to the back of the car and take loose the exhaust hangers so it will move and try to pull the I pipe away from the y pipe
Old 01-07-2010, 05:18 PM
Gordo78's Avatar
Did that already. And the y is off of the manifolds.
I'd like one of those exhaust disconnect tools but there isn't one in this town...
01ssreda4's Avatar
They used to carry them at HF, but I cant seem to find them now.
Old 01-07-2010, 05:20 PM
Gordo78's Avatar
Closest harbor freight is an hr and 45 mins away
Old 01-07-2010, 05:41 PM
Peeler12's Avatar
BFH and patience. I spent forever on mine also... I just kept beatin on it an it eventually came off.
Old 01-07-2010, 05:49 PM
Gordo78's Avatar
I'll beat on it some more. A friend of mine will be around a harbor freight tomorrow, anyone have a link to one of these disconnect tools?
Old 01-07-2010, 06:53 PM
01ssreda4's Avatar
Another option is buy the correct sized exhaust U clamp. Tighten it on the pipe. And that gives you something to beat on. That has worked for me before.
Old 01-07-2010, 06:55 PM
Trans Am Jam's Avatar
sawzall worked for me
Old 01-07-2010, 06:58 PM
01ssreda4's Avatar
here is one from summit
http://cgi.ebay.com/ebaymotors/Summi...motiveQ5fTools
Old 01-07-2010, 07:18 PM
DarkJuggalo's Avatar
i just used a sawzall on mine, and still had to cut a bit more for the ORY to fit right
Old 01-07-2010, 10:02 PM
pheer's Avatar
i got the bolts holding it out, then jus swung it back and forth andit slowly slid out... oh, i did spray some PB Penetrating lube into the joint, not sure if it helped, but i did it...
Old 01-08-2010, 01:26 AM
01'SSLSX's Avatar
+1 for the torch method, works EVERY time
no need to buy tools, if u dont have a torch a local exhaust shop should help u out for cheap. this is not hard, just a pain. oh yeah, dont cut anything. lol
Old 01-08-2010, 01:31 AM
ssman00's Avatar
lies!!!! yours came off very easy haha you havent seen a difficuclt one yet.
op id go to your local hardware and get yourself a handheld torch and heat it up. it should slide off
Old 01-08-2010, 04:15 AM
f-bodyguy's Avatar
op if your going to spend money take it to a shop they might charge you 10 bucks and some hole in the wall exhaust shop..just my 2 cents...good luck and try swinging it back and forth it took alot of kicking and swinging to get mine off again good luck
