Generation IV External Engine - Electric water pump power supply
RsSean
01-07-2010, 06:13 PM
I am literaly in the process of putting on my Meizer electric water pump. Was wondering where you guys are pulling the power from?
Pic would be best
Thanks
Jontall
01-07-2010, 07:30 PM
Have to use their relay and pull power right from the battery.
2000_SS
01-07-2010, 09:05 PM
ls1howto.com has a great write-up for installing a Meziere pump on a F-body.
They use a relay with power from the (+) terminal on the fuse box with a 12v switched source coming from the large pink fuel pump wire under the fuse box
99Bluz28
01-08-2010, 01:36 AM
I did the same except I went and connected my water-pump relay turn-on wire to the gray wire coming out of the fuel pump relay on my 99 Z28.
RsSean
01-08-2010, 08:07 AM
Well WTF mine did not come wioth said relay. This horse hockey. Well I guess I am just going to fuse it and go to the fuel pump.
2000_SS
01-08-2010, 06:59 PM
go to ls1howto.com....they list the part number for a borg warner relay you can get at any parts store.
shoemike
01-08-2010, 09:47 PM
I plugged mine into one of the headlamp door slots (camaro)
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
