throttle body question
Old 01-07-2010, 07:44 PM
purplez281998's Avatar
Default throttle body question
getting a fast 92mm intake.my question is would a 90mm fast or nw throttle body work fine?i know a 92 would be ideal but just curious if a 90mm is all one could come up with.thanks
Old 01-08-2010, 07:30 AM
teke184's Avatar
why wouldn't it.
sure there'll be a SMALL ...1mm...lip on the mating surface, but its not enough to make a performance difference.
if that's all you can find...go for it
Old 01-08-2010, 09:44 AM
Jon@Texas-Speed's Avatar
Yeah it should bolt right on. Won't be a huge difference if you went with the 90mm. People run the 90mm LS2 TB's on the FAST 92mm intakes all the time.
Jon
