799 heads any luck with these
If you go aftermarket like comp cam or anything bigger than ls6 cam, Id grab a set of double springs or some beehives that will handle the lift on the new cam.
Doing heads/cam goes hand-in-hand, esp IF you are for sure doing the heads like in you're case. You will already have 90% of the stuff off the block to do it and the extra kick in the *** when you stomp on it will make it well worth it to do it all now. Adding a cam on your Ls1 with the 799 heads will help a ton more than just using the heads alone. Will def wake that engine up!
JUST REMEMBER IF YOU DO A CAM TOO, TO MATCH THE CAM AND HEADS WITH THE ENGINE. THINK about what you want as far as goals, the valvetrain is very important on these engine and MAKING the right setup can have a huge impact on the performance of the whole engine/car, in a good way of course
