decided on the CTS oil pan
Old 01-07-2010, 11:48 PM
brax 69 chevelle's Avatar
Default decided on the CTS oil pan
well, after thinking it over for a lil while, i went ahead and decided to buy the CTS oil pan for my LS Chevelle swap. The LS1 is going in a 69 Chevelle, and the F body pan that i originally tried wasnt working out for me. I ordered the CTS pan, and received it today. Hopefully it fits!!!
Its freezing ***** cold in my shop right now, so i haven't test fitted anything yet, but when i do I will let you all know how it works out!
Old 01-08-2010, 12:09 AM
bczee's Avatar
It should give you more room between the pan and crossmember, but still can be a pita to get the engine in but once it does get pass the front crossmember, you should be good. It also is the reason why I went with it 4 years ago...
Post some picture once you get it positioned ..
Old 01-08-2010, 11:08 AM
lamdenali's Avatar
what is the different bet. the CTS and truck pan. can someone post up some pics pls. am dropping the motor and tranny in tonight with the truck pan. I know the truck pan hang low , but is the CTS hang low too ?
Old 01-08-2010, 06:42 PM
bczee's Avatar
The F-Body is about 5.5", CTS is about 6.5", the truck is about 8" of drop in the sump.
Old 01-10-2010, 09:44 AM
lamdenali's Avatar
I drop mine in and the truck pan hang too low in the front and it hit the center steering link. I then order the mod F body pan from S & P . will try it again when the pan come in
Quick Reply: decided on the CTS oil pan
