Fuel lines for LS Chevelle swap
When i first started building my Chevelle, i was gonna stick with a carb. I ran new aluminum fuel line from the tank to the engine. can i still use this line at all? im not sure if the line was rated for fuel injection or not, but i figured if nothing else, maybe it can work for my return line back to the tank. Im wanting to run a pretty stout fuel pump, probably around 80 PSI or so.
If this aluminum line wont work for fuel injection, then where can i find some reasonably priced metal line to run along my frame?
