Generation IV Internal Engine - WHAT sort fo motor is a L98??LS2
QCK57
01-08-2010, 04:09 PM
can some one give me some info on this???????
Is this a LS2 block with L92 heads????
Dutchman427
01-08-2010, 07:04 PM
No it is not. It was a 5.7l engine used from 85-92. TPI motor.
oldguy99Z
01-08-2010, 08:24 PM
I would agree that a L98 is a older 350 Chevy engine but I have seen L98 used in some threads on LS engines-this was by Australians.Apparently in Australia GM uses different designations for their engines.I don't know if its a LS2 or LS3 or what.
Tom@SpeedInc
01-08-2010, 09:53 PM
correct.
someday
01-08-2010, 10:53 PM
correct.
where is the L98 listed? is it an overseas motor? so its like an LS2.5?
what about an L76? does that have the rectangle port heads? wouldn't that be the 6.0 with L92 heads?
gnfan
01-08-2010, 11:00 PM
Yes , they use this combo in Australia
SS Enforcer
01-09-2010, 12:14 AM
Ok it's a L76 without any DoD hardware is probably the best way to describe it. 6.0L with l92 heads and is used in GM models in Australia from 2006 to the present. The later autos have the DoD enabled.
I had one in my 2006 VE/G8 Holden Commodore.
cheers
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
