transition from rubber to hard line on 9"
Old 01-08-2010, 09:04 PM
getusumws6's Avatar
Default transition from rubber to hard line on 9"
Those of you with a standard Moser 9" housing w/ TA support bolted on, How did you transition from rubber to hard line on the rearend? did you cut the 10 bolt plate and tack it on to the housing ( stock location)? The last rear I bought was from MWC and Eric had fabed everything needed. Do I need longer rubber brake hoses?
Thanks for any input. Pictures would help also, so I can get a placement idea.
Thanks
Corey
Old 01-08-2010, 09:32 PM
99_Z_155's Avatar
i just took the bracket off those two lines, gave em some slack, then zip tied everything to the axle tubes.
Old 01-09-2010, 03:20 PM
mattl31's Avatar
http://image71.webshots.com/71/0/86/...6DFCxdA_fs.jpg
theres what i did. just straightened out the factory lines a little and ziptied to the axle tubes with some heaterhose to prevent any potential rattles
Old 01-11-2010, 02:26 PM
getusumws6's Avatar
The link didnt work. And To be honest, i'm not into bending stock lines and zip-ties. ( that is a quick fix in my book ) Thanks for the relpy though.
Corey
Old 01-12-2010, 11:21 AM
mattl31's Avatar
Corey
lol trust me nobody is going to be more particular than me. they ended up looking really really good. only alternative other than that that i would have considered would be stainless braided. good luck then
