800-1000RWHP Which Spec Twin
Old 01-08-2010, 10:01 PM
FI402Z's Avatar
Default 800-1000RWHP Which Spec Twin
Based on my research on here the Spec twin is the best streetable clutch for the 800-1000RWHP crowd. Unfortunately when I went to Specs site, there are 5 twin discs. Just looking for a little clarity on which one would be best in a DD.
Old 01-09-2010, 06:49 AM
Kurtomac's Avatar
what are you using the car for? The PT trim which a lot of people run with fantastic results is good to 1395lbs of tq....this would be the best all around for a street car with that kind fo power...if youre going to track it often...I would consider maybe a higher level...these clutches are rebuildable...I run the PT trim in my Z06 it holds great and drives good on the street
Old 01-09-2010, 07:17 AM
FI402Z's Avatar
Mostly street, limited track. Thanks for the advice! How harsh is the engagement and disengagement with that trim?
Old 01-09-2010, 07:18 AM
Nimitz87's Avatar
I'd look elsewhere for that power level than spec but that JMO.
Chad
Old 01-09-2010, 07:29 AM
FI402Z's Avatar
Well, I heard the McLeods with put hell on the input spline shaft at those power levels. Guess you would recommend the Tex Exo Skel? Those were the top 3 I could figure after hours of research. I do appreciate any input. Thanks!
Old 01-09-2010, 02:50 PM
Kurtomac's Avatar
I'd go Spec twin PT, RPS twin or tripple, or McLeod RXT twin...the tex twin isnt enough for that power
my engagement isnt that bad...its just a short engagement window but i can slip it from a stop or slip it from 4000 at the track on the launch...good clutch...takes the heat...keeps on going...bites real hard when you ask!
Old 01-09-2010, 02:57 PM
airforcemanss's Avatar
^so what clutch are you using? you didn't say
Old 01-09-2010, 04:15 PM
Kurtomac's Avatar
I didnt? Read harder...PT trim spec twin
Old 01-09-2010, 04:39 PM
i forgot you posted in the 2nd post der...
Old 01-11-2010, 09:00 AM
SPEC-01's Avatar
The PT-Trim is a great option but we do offer 4 different versions of the Super-Twin. Let me know what kind of torque you are making and I will be happy to provide a recommendation. I have provided a link to our webpage specific to this application so you can see the torque ratings and prices for each model. These kits include a steel flywheel but we also offer an aluminum option for those interested in reduced mass for $89 more. Take a look and let me know if you have any further questions. Thanks!!
http://www.specclutch.com/cars/Chevy...002/Super_Twin
Quick Reply: 800-1000RWHP Which Spec Twin
