New PArts installed, NOW PROBLEMS
Old 01-09-2010, 10:54 AM
jds99camaross's Avatar
Exclamation New PArts installed, NOW PROBLEMS
Before the install I had a cam only 99 ss ran perfect. I decided to put heads, fast 90/ and a 90mm TB with 42lbs Injectors on at the same time. Now, i have hp tuners and have a tune that i thought would have been close to the setup i have. I uploaded it. and tryed to start the car, It started and idled for about 1-2 secs at 2500rpm then imeadiatly spiked to about 5500 and i shut it off. I also have had it just shut off on me right after it started ran for about 2 secs. Im not sure if this is mechanical or the tune, I tried my old tune to see if it would run and it does the same thing. Any ideas???
jds99camaross is offline
Old 01-09-2010, 12:16 PM
MjMaro's Avatar
Any vacuum leaks or unmetered air getting into the tb/manifold? May be a good place to start since you said it was idling at 2500 and jumped to 5000. That would also account for why it did it with both tunes instead of just the new one. If I can think of anything else I'll put it in here.
MjMaro is offline
Old 01-09-2010, 12:24 PM
jsteele90's Avatar
sounds like a vacumn leak to me. check your throttle cable too make sure it isnt pulling the tb blade open.
jsteele90 is offline
Old 01-09-2010, 03:48 PM
I did, Just pulled the intake off there is a crack on the bottom of the FAST 90mm intake, Almost sure thats the problem, im going to put my ls6 intake back on to rectify this problem/ Then fix the crack.
Old 01-09-2010, 04:00 PM
SweetS10V8's Avatar
Did you change the bolts on your valley pan?
SweetS10V8 is offline
Old 01-09-2010, 09:10 PM
nope i did not
Old 01-09-2010, 09:14 PM
1BADTALS1's Avatar
how the hell do you get a crack in the intake? i hope you didn't buy it that way....
1BADTALS1 is offline
any suggestions on the fix? I was givent he intake from my father i wish i would have known before
Old 01-09-2010, 09:17 PM
1BADTALS1's Avatar
Hmm maybe a two part epoxy that can handle the heat and pressure.. not sure tho.
Old 01-09-2010, 09:32 PM
edwardzracing's Avatar
Originally Posted by jds99camaross
nope i did not
That's why it cracked... the stock valley pan bolts are too high for the FAST 90 to mount correctly after being fully torqued. I'm surprised you didn't hear it crack as you were tightening the intake bolts. Did you inspect the intake before you put it on? I don't know for sure, but I believe a new intake is shipped with the new valley pan bolts, so I'm guessing you purchased the intake used? Hopefully someone didn't sell you junk. You might be able to epoxy it back together, but I wouldn't know. Ask around and see what people think. Good luck... sorry about the bad luck.
edwardzracing is offline
Old 01-09-2010, 09:45 PM
it was given to me from my father, he got it used to. He didnt know it was cracked either. I will try to repair it. thanx for the help.
Old 01-09-2010, 09:57 PM
badss_02's Avatar
JB weld man, If it can save a turtle's life it can probably save your intake...
badss_02 is offline
Old 01-09-2010, 10:56 PM
LSX Mechanic
Damian's Avatar
Do not make multiple posts in multiple sections on the same topic. Thanks.
Damian is offline
