what do i have to change on a 5.3 or 6.0
Old 01-09-2010, 10:09 PM
birdmanta's Avatar
Default what do i have to change on a 5.3 or 6.0
i have a 99 z28 what all to i have to change to make a 5.3 or a 6.0 bolt up i know both engine will go straight in but and i know it is a plug a play but will i have to change the oil pan and oil pump and if you have any other info let me know thanks........
Old 01-11-2010, 12:21 PM
Zman98's Avatar
Might post in the conversion section. Might get more interests there.
Old 01-11-2010, 12:40 PM
tspence45's Avatar
I think you'll have to use an Fbody oil pan. From what I've heard, you have to drill and tap a hole for the alternator bracket to bolt up too. Otherwise, everything else should work just fine.
