reduced engine power?
i've got a problem here. while on the highway in 4th gear at about 4k rpm i went wot and then immediately rpms dropped to about 1800 and the screen said reduced engine power. i had to putt it home with it not letting me above 1800rpm. Even in neutral it stayed around 1300 to 1500. I checked the code and it was p1514. TAC maf performance. My maf has been descreened and gutted thanks to my dumb *** friend talking me into it. It was then dyno tuned due to it having a crappy idle and inconsistent performance. The tune was done 3 months ago, it has been fine until now. Do i need a new maf? Any help appreciated.
Disconnect the negative lead from your battery, pull the maf and clean it with some MAF/electronics cleaner. The battery being disconnected for a little while should reset your PCM. You may very well need a new maf since yours was gutted, possible its throwing off the pcm. You should be able to pick up a used un-molested MAF cheap around here.
I looked at the maf and it was ok. Then i disconnected the battery, hooked it backup and now it runs fine! I'm thinking i need a stock maf though to prevent it from doing this again.
