Replaced PCM, now I can't get my trans to shift right!!
Old 01-10-2010, 01:51 AM
02_ramair_ta's Avatar
Default Replaced PCM, now I can't get my trans to shift right!!
I have an 01 formula, h/c car, runnin a 4200 stall. I replaced the PCM due to a #7 coil issue, that ended up bein a bad computer.. But now the car won't shift. I used hp tuners to flash the tune from one computer to the next, so I'm lost. The PCM I'm using is out of an 02 ta 6spd car, but I've been told that they are all the same, part numbers matched up, so I installed it. It fixed the #7 coil issue, no code, and it's firing, just the car won't shift, like it's untuned?? Maybe I missed something??
Old 01-10-2010, 03:36 AM
JonCR96Z's Avatar
Did you do a 'write entire' or just a 'write calibration'?
It should work fine if you did a 'write entire'.
Old 01-10-2010, 11:47 AM
First I did just write cal. Then went back and wrote entire.
Old 01-10-2010, 12:30 PM
sssalah's Avatar
check the calibration details in the edit menu, it should have the tranny type.
Old 01-10-2010, 02:46 PM
Well it shows manual!! How do I change that? Thanks for the info.
Old 01-10-2010, 03:02 PM
JonCR96Z's Avatar
Your old PCM was for a 4L60E? Do you have a copy of a tune that has a 4L60E for the trans?
Old 01-10-2010, 03:09 PM
Yes the old PCM was from the a4 car, I copied the tune onto a file for a m6 car. Thinking it would be an easy swap.. Guess I was wrong. Do I just need to buy credits for the auto, then flash that onto the PCM instead? Or is there a way to switch the trans?
Old 01-10-2010, 03:22 PM
JonCR96Z's Avatar
So you didn't have the 01 PCM licensed? Not sure how the emission laws are where you at, but you may have to do that anyway to get your 2001 VIN correct.
Old 01-10-2010, 03:30 PM
I'm from Texas, so no worries, but I see what your sayin. Now if I licensed the tune from the 01 auto car, then flashed that into the PCM, that should fix it huh? Well so much for the cheap route!! Lmao
