Pictures of Main Nitrous Feed line
I don't have any pics, buthere's the breakdown--
run the line from the back through the rear plastic. Remove the passenger side rocker trim (by the seat) and run the line under there. Be careful not to hit the line when reinstalling the screws. From there, there is a rubber grommet on the firewall by the PCM. Pull the line through there and route the line where you like the best. Be careful to keep it away from heat sources like the headers.
Hope that helps
Hope that helps
i ran mine from the spare tire mount under the pass.rear seat under the front console,under the drivers carpet and out the firewall thought a groment and wirring with it.nice neet and cant see it.
