LS1 coils same as LS2?
Old 01-11-2010, 08:48 AM
ADM
ADM's Avatar
Question LS1 coils same as LS2?
I just want to know if the LS1 coil and the LS2 coil assemblies are the same?
As in, do they use the same connectors? It doesn't matter if one produces slightly hotter spark than the other, just want to know their interchangeability.
Thanks guys.
Old 01-11-2010, 10:43 AM
ADM
ADM's Avatar
No one knows the answer?
Old 01-12-2010, 03:44 PM
MASS seller approved
smok'nZ's Avatar
yes LS2 coils are interchangeable
Old 01-12-2010, 05:58 PM
LS1MCSS's Avatar
You will probably need different brackets. I am pretty sure they are different.
Old 01-12-2010, 10:02 PM
InsaneDomestics's Avatar
Depending On What Car You Have You Will Need To Swap Brackets. The Fuels Rails On LS1 Cars Sit Closer To The Intake Than Those Of An LS2. I Swapped Coils From An 06 GTO To My 98 Camaro, Everything Was Plug And Play, Just Had To Swap Brackets
