Picked up LS9 Head Gaskets - Pics and info inside
Old 01-11-2010, 06:36 PM
KILLER-LS1's Avatar
Default Picked up LS9 Head Gaskets - Pics and info inside
So I just picked up some LS9 gaskets, and there seems to be a lot of confusion on the exact specs.
im not sure if this is the correct way to check thickness on the gasket, but squeezing the dial calipers a little bit showed 0.052 - 0.053 ish thickness, depending on how hard i squeezed, and 0.048 right next to the rivet.
bore size is 4.100
7 layers, 4 "active" and 3 "inactive layers"
these fit on my 4.010 bore, and went over my ARP studs just fine. the gasket fit PERFECTLY around the dowels with no extra play.
if anyone needs more info, let me know
Old 01-11-2010, 06:39 PM
NemeSS's Avatar
Old 01-11-2010, 06:55 PM
GMCtrk's Avatar
Nice. Where did you get them from and cost?
Old 01-11-2010, 07:04 PM
KILLER-LS1's Avatar
I just ordered them from my local dealership, tustin chevrolet. obviously they were a special order and came straight from detriot
im an ex GM technician, so i get a good deal on parts, but i paid $80 for the set. id guess you'd spend about $100-120 ish at full price, but who knows, call up a dealer and see what they quote you...
Old 01-11-2010, 07:12 PM
NemeSS's Avatar
SDPC usually has them in stock.
Old 01-11-2010, 07:26 PM
HUNTER02SS's Avatar
They look just like the 6.2ltr. gasket's for the escalades.
Old 01-11-2010, 07:29 PM
KILLER-LS1's Avatar
well according to the dealer, there was only 1 other dealer in the whole united states with a set in stock. it wasnt a big deal to order it. it only took like 4-5 days
NemeSS's Avatar
i dont think there the exact same gasket,
diff. part no. i think
Old 01-11-2010, 07:33 PM
KILLER-LS1's Avatar
the difference is:
stock 6.0 gasket is a 3 layer,
escalade 6.2 gaskets are a 5 layer,
LS9 (ZR1 corvette) are a 7 layer.
what i like the most is that GM Performance Parts lists them for "forced induction applications" if you look up any other gasket, it says "for naturally aspirated engines only"
Old 01-11-2010, 09:12 PM
Restricted User
98Z28CobraKiller's Avatar
.5 is a 1/2 inch thich. .05 seems too thin for a 7 layer gasket. Anybody know for sure where to take the measurement?
Old 01-11-2010, 09:29 PM
GMCtrk's Avatar
What's the consensus on using these on a 4.00" bore versus the 4.03" 6.0L gasket?
Old 01-11-2010, 09:50 PM
omore01's Avatar
Used these same gaskets on my 370 turbo build, they fit perfect. $80 from the dealer for the pair sounds real good, I picked them up from gm parts direct for $35 a piece earlier last year. They are doing great so far, I'm sure they will hold a significant amount of boost for a long time.
Old 01-11-2010, 09:54 PM
KILLER-LS1's Avatar
sorry youre right, i made a typo. it is .052 - .053
however it is apx the same thickness as the other gaskets because each layer is thinner, allowing for more layers to be the same thickness as the other gaskets
Old 01-11-2010, 10:15 PM
SilverSS's Avatar
What's the thickness where it's compressed by the rivets?
Old 01-11-2010, 11:06 PM
KILLER-LS1's Avatar
Originally Posted by silverss
what's the thickness where it's compressed by the rivets?
just went out to the garage and double checked...
0.048" which puts it right on par with the actual compressed thickness of the stock 6.0 gaskets
Old 01-12-2010, 02:24 PM
Restricted User
That's good the know. I was hoping that they were a little thicker than the 6.0 gasket to help drop compression a little bit.
Old 01-13-2010, 01:35 AM
KILLER-LS1's Avatar
yeah, but at least they are a benefit in other ways, im sure they can hold much higher cylinder pressures....
Old 01-13-2010, 01:32 PM
cjmatt's Avatar
Can anybody confirm that the LS9 and LSA use the same head gasket part number? or does the CTS-V use a different gasket. If they are different part numbers their may be another option while the LS9 are out of stock
Old 01-13-2010, 01:54 PM
KILLER-LS1's Avatar
out of stock, and not a stocking item are different. they ARE in stock, but only in the warehouses. it shouldnt take more than a few days to get a set.
Old 01-13-2010, 01:56 PM
cjmatt's Avatar
well, just an FYI, but there are alot of cadillac dealers with these in stock for the CTS-V. I just called up a dealer and they directed me to a dealer about 40 minutes away with a set in stock. Ill be grabbing them tonight
Quick Reply: Picked up LS9 Head Gaskets - Pics and info inside
